Stingray 180RX w/ Volvo SX outdrive
So when lifting the trim up, it sprays hydraulic fluid out of the 4 way manifold. I removed the retained and noticed the the far right one wasn't seated correctly. I would like to investigate whether that was the simplest fix ever or i need to replace some parts but can't figure out how to add fluid? OR, what type of fluid to add. Volvos manual is silent to this topic, any help?
Also, a quick google search turned up a bunch of people with the same year boat and the same outdrive and the same issue or worse (leaking pump). This is clearly an issue with volvo quality.
I need help, i feel a giant bill from the dealership if i can't get this working.
