Re: trim/tilt-leakdown
The end of the valve that goes inside the pump body is an aluminum cap. remove the o-ring, use a screwdrive, with rag wraped around tip, insert tip in groove where o-ring was located, keep twisting to remove cap. Boiling hot water on the valve will help. DONOT use flame, it will ruin spring.
