Trim Tilt motor replacement help
conormacg
Good evening,we have a 1986 Johnson 200 hp and have ordered a new trim tilt motor, old one is corroded and junk.
Started looking at the way its mounted, and now would appreciate help with what would be the easiest way to replace this motor.
(a) do I have to pull the motor off the transome to do this job?
Seems like the unit needs to be tilted somehow to access the third screw close to the transome bracket.
Any help or links would be very useful, dont want to pull off too much stuff if not necessary, and also want to be careful not to damage anything including myself...thanks
