Hey all, new here, great site and really good advice from what I've read. I have a 1988 (pretty sure) 115 Mariner on my boat with the original trim/tilt system that it came with. It was leaking and got water in it, so I followed the book and rebuilt the entire thing...every o-ring, seal, etc. in both rams and the tilt cylinder, plus a new pump w/ motor. Everything seems to be working fine except...when the tilt gets down to the rams, it more-or-less stops right there (pump still running of course). If I push down on the outboard it, it goes down/in about 3/4" and pops right back up...just like the book says...so I assume I have air trapped in the big cylinder...? I have cycled this thing WAY more than I should have had too...sometimes it burps (self-bleeding system supposedly), sometimes it doesn't, but hasn't yet changed the performance. If I put pressure on it while going down, sometimes it will go all the way down...but it doesn't screech or sound like it's processing air when it gets to the lowest point??! Any suggestions on verifying this is trapped air? Drain the system and start again...? Could it possibly be a faulty check valve (if mine even has that)? I've also noticed the hydraulic fluid is generally frothy when I open the filler plug to check the fluid (after cycling it of course). Thanks!
