New motor to me and had labor day problems ;-(
Issue...
Has run perfect and trimmed/tilted as expected. Today put the motor up at end of day and went up fine. Flipped the trailering brace /lever and dropped the motor a sliver to rest on the lever. As soon as I did this the trim motor stayed making awful grinding type sounds. Very consistent sound but much louder than it should be. The motor doesn't trim tilt AT ALL now. Just makes loud sound when switch is hit up or down.
Never dealt with trim systems much. Pulled the full plug and seemed like it was underpressure. Some fluid came out. ..not allot. ...very light milky looking but still very oily.
If the pto on the trim pump was a gear I would say the great is stripped....that's the sound its making. Trim pump? Whatever the trim pump hits? Thoughts? Tests I can run for more info?
Thanks guys
Rob
Seattle wa
Issue...
Thanks guys
Rob
Seattle wa
