Trim/Tilt problem
Doernuth
Ok, I have dual 165 Mercs from 1977/1978 pre alpha outdrives.
The Port trim works just fine but the starboard is now a problem.
Here is what it does...
Goes down fine.
When you try to go up it starts up then stops almost immediately when you push the button. It worked fine last summer.
Hotwiring the solenoid gets the drive to go all the way up.
Is this a solenoid problem? or a button problem. Buttons are not on the throttle/shift assemble but are on the Helm below the steering wheel.
Any help or suggestions greatly appreciated.
