I have a 40 hp johnson with trim and tilt. Im having trouble with the trim/tilt, can I remove the fluid and use the boat without the trim and tilt and just raise and lower it manually just by passing the trim/tilt ? Also I know it locks when raised up but will it lock in the down position as well. I just dont have the money to fix now but still want to use the boat. Thanks for your time. Tim
