arsenalpsu
- Joined
- Dec 1, 2008
- 290
I have a 1984 merc I-6 which the tilt is leaking. What is the best way to remove the Groove Pin from the arm of the Tilt cylinder? It looks as the head is larger than the shaft so i can't just punch it through. I can't get at it from the other side, can anyone offer a suggestion? (drill it out etc..?)
Once that is out I plan to swing the tilt cylinder down and remove the end cap and replace the O rings. Any suggestions or tips on that?
Thank you.
Jon
Thank you.
Jon
