I have been converting a manual tilt 1980 50 HP Merc to trim/tilt. Everything is hooked up but the wiring harness from the Trim/Tilt to the switch is not with the unit.It appears to have a 3 wire connecter at the trim motor that the harness plugs into along with 2 wires from the limiter switch that looks like it plugs into the missing harness. I guess my question is can an after market switch be wired into this unit or do I need an OEM harness? I'm not having very good luck finding an OEM harness. Any suggestions!!!!<br />By the way this is a Trim/Tilt 1984 50 HP tiller model.<br />Thanks,<br />Fred
