1985 OMC 3.8L, V6 with power trim/tilt. Can't get it to come up or down. Got it down one time and that was it. I have power to the motor, and it clicks when I hit the switch both up and down, but stern won't move. I took apart the Tilt Clutch Assembly. It was full of water and very little oil. I cleaned it all, fresh oil and put it back together but it still didn't work. I'm baffled.<br /><br />When I put it back together is there any secret to how the cross bar tilt clutch that goes through the tilt clutch shaft is supposed to be positioned? <br /><br />I took it apart and put everything back in the same order.. So...I don't know where to go next.<br /><br />Could the tilt motor be bad? I thought it was ok since it lowered it the one time.<br /><br />Also, this thing has been sitting for about 4 years and I'm having a problem finding an ignition tune-up kit. Anyone know where I can get one on here? Thanks.<br /><br />Thanks,<br />Cal
