1988 Merc 4.3 185hp Alpha outdrive<br /><br />I know the trailer setting ( when I raise the outdrive from the forward controls) is at full up. Where should the tilt setting be? I completed several repairs on the boat and had to take off the bell housing and trim senders. During testing after reassembly, both trim and trailer brought the outdrive all the way up. I have re-adjusted the trim so that the sceg is even with my keel at full up. Trailer will bring the outdrive all the way up. Is the trim setting right?? Or should it be still lower in the water. My manual says never to run the boat with the prop higher than max trim , but it does not mention what that position, should be. Thanks. MJS.
