BuggsIslandlake
- Joined
- May 15, 2006
- 19
My trim unit does not raise or lower the 88 hp johnson. it has been sorta erratic over the last couple of years, sometimes it will go up and sometimes not. Early last year a friend said the relays(there are two) seemed to be corroded. So i replaced them and the unit worked fine for most of last season. But then it stopped working. I had noticed that the socket that one of the relays fit into had some black sticky stuff around the plug in. I have figured that it is the socket which has all the wires attached to it that is bad. I talked to a Nappa dealer in town that sells parts, relays,etc for Johnson and other engine brands but he was not able to get the socket. He told me before getting the new socket to clean the openings with contact cleaner and really clean the contacts and maybe it would work. Would anyone know if one bad socket would cause the trim from working up and down. And would cleaning make it better. Also, there are two sockets and where can i buy them if cleaning doesn't work. Thanks for the help.
