Trim up and down really slow
exnavyman123
Can anyone help, my trim motor is barely moving the powerhead up and down, on the up it just clicks ......
Helloooooooooo !!!!!!!!!! Can anyone help please?
I checked the connections, all tight and clean, i found out the trim motor wires connect to the engine battery, it's a astrolite 24M captain and is at 9.8V, is this a 24V battery and less than half charged, or will the motor not raise unless it is at like 11 or 12volts???????
exnavyman123
Re: Trim up and down really slow
KellyC
you have a very weak battery my friend. Try charging it and then give it a shot.
exnavyman123
is it a 12 volt battery or 24 that i have?
if it is a 12 then it is only 2 volts low and that would cause this problem?
exnavyman123
Don't everyone answer at once? Lol i guess no one knows ........
exnavyman123
i need to get the motor up so i can store it for winter, i only have a few weeks left before the freezing temps come so quick responses are appreciated !!!!
riptide09
The battery should have the voltage on it. I would bet 12V but don't take my word for it. Check and then charge it up. While it is charging check the hydraulic fluid and top off if it is low.
Brewman61
Ensign
FYI, a 12V battery is considered fully discharged when it's voltage drops down to somewhere near 11V, perhaps even a bit higher.
At 9.8 volts, your battery is done.
Try recharging it to full state and try again.
Also try being a little patient with soliciting free advice from the forum. It's a weekend, and many are out and about so it may take many hours to start getting responses.
You said you have weeks till it freezes, yet you're freaking out because you haven't gotten answers to your questions within 3 hours?
Calm down. Go recharge your battery. It's likely a 12V battery, so it should read 13V or so when fully charged. Then try your trim.
Brewman is absolutely correct, on all points.
At that low of a voltage is a wonder it's doing anything.
exnavyman123
Thanks brewman/all it works fine now, never expected it to have to be around 11 or 12 volts to work at all.....
spdracr39
In case somebody searches. It could be low on oil also.
bassman284
I think you have a new battery in your future. There is little chance that battery will take a charge although you might get enough in it to raise the motor.
