Trim up button makes motor go down, right?
Mark42
Got me one of those fancy Italian throttle/shift controls to run my Johnson 90hp. Following the connection instructions, I hook up the tilt/trim button and test it out. Yep, press up and motor goes down. Press down and motor goes up. Double check the instructions and wire colors on the control. Yep, its wired just like the instructions say. :facepalm:
So I reverse the wires (white to johnson blue/white and green to johnson green). Now the up button makes the motor go up, and down makes the motor go down.
Lots of grammar mistakes in the instructions. The tilt/trim wire connections must have gotten messed up in the translation...... :D
Well, at least I didn't have to switch the forward/reverse shift cable....
Woodonglass
Re: Trim up button makes motor go down, right?
Sounds like my WIFE. If I want her to turn Right I tell her to turn LEFT.... You think I'm Kidding!!!!!:rolleyes:
oops!
lol....key word mark is italian....
they are on the other side of the world.....like the auzzies and upside down.......the other side kinda gets things backwards.....tee hee.
glad you got it sorted out
sschefer
The ABYC standard is blue (sky) = up, green (earth) = down. No, I'm not kidding. Look up and see the blue sky. Look down and see the green earth. It's an easy way to remember it.
mark1961
Ensign
Ay no problemo.....just turn de switch upside downa! :D
mark1961
Ensign
Psst! Italia is in the other hemisphere like you canucks, i hear they play ice hockey too.....:rolleyes:
Our sparkies are just fine here thanks.....:p:D
