ccave04
- Joined
- Sep 7, 2011
- 104
Hello,
I am a new boat owner and have searched the site a bit and found many threads on what may be the cause of this but I am stumped as how to fix the issue.
Boat Info:
20' Open Bow Marada 198 Ske
5.0L V8 Merc Engine
Alpha One Merc Outdrive (Serial No. 0L715730, Drive Ratio 1.62R) Not sure what Gen this is...
Here is the issue. The trim up/out button on the throttle is no longer functioning. The trailer button will bring the trim all the way up still and trim down/in still functions correctly. The trim motor is located on the port side of the boat just sitting on the other side of a firewall. I am not sure if this was a replacement trim motor and the previous owner didn't mount it or what the reason for this just sitting here is, but I assume I should probably mount it to something? The mount that it is hooked to currently is rusted all to hell and crumbling away.
Anyways in the fall when winterizing my boat I ran into some issues and we pulled that whole firewall on that side and were kicking around in there for quite a bit messing with a stuck plastic drain plug. My first thought was that while thrashing around with the plug I kicked / broke a wire somehow, but upon closer inspection everything looks connected and in the right places. From what I have read it sounds like it might be a trim limit that may have gone bad ? I don't know how to check that if someone can give me some direction from pictures below I would be greatly appreciated. If you need any better views of anything let me know I can take more.
Boat Info:
5.0L V8 Merc Engine
