trim will go up, and leak back down..?
jserb
like the title says boys, my trim will go up no problem, but then it will slowly seep back down. I have a 1989 evanrude 235 hp. i know nothing about tilt and trim so your help and sugestions will be greatly appreciated. i has one cylinder and i dont know where to start. fire away boys!
ob
Re: trim will go up, and leak back down..?
One easy fix possibility is that the manual tilt release screw is not against its seat.Worth a look.Should be accessible through a hole in the side of the transom bracket.Careful,the release screw head tends to crater easily if you don't use the right size driver.Make sure the reservoir is topped off as well.You can do this by tiltiing the engine up and supporting it from leaking down.Then ,remove the fill screw on the tilt reservoir and insure that it is full to the point of weeping out of hole.Reinstall reservoir plug and run the engine up and down several times to prime.<br /><br />Otherwise,you may have a seal issue.Trailering without a support in the tilted position can lead to premature problems.Is there any signs of external leakage?
