Re: Trim Works But Makes Clicking Noise
Just a real quick stupid question: when I connect it directly to the battery, the trim will go up or down as soon as the connection is made, correct?
I'm assuming since I'll be bypassing the switch and solenoid, that is what will happen. Right?
1996 used both 2w and 3w trim motors.
If your trim motor has a black wire then it is 3w with blue = up, green = down, and black is common ground. If you hook up both green and blue at same time then you are telling motor to spin in both directions at once. So, never, ever, ever hook up both at same time on 3w motor.
If your trim motor only has blue and green then it is 2w. 2w does not have a ground. You flip the polarity of blu/grn motor leads to make motor spin in reverse.
That said, the answer to your question is yes. Hook motor up directly to battery and either motor works or is broken. No room for anything else except dead battery.
