Trimming an outboard
braindead0
I searched around, but trying to search for 'outboard trim' returns tons of stuff, usually about power trim ;-).<br /><br />I'm guessing that I want the outboard to be verticle when up on plane? Are there any good web resources for trimming hints, pictures and the like? <br /><br />I think it's trimmed about right.. but I don't know for sure (I'm mostly a sailer ;-).
JB
Re: Trimming an outboard
Moving to General Outboard
braindead0
Just outta curiosity, is the procedure for trimming different with an O/B verses a stern drive? Just curious, I figured it'd be roughly the same..except of course your stern drive probably has power trim ;-)
Hooty
Ideally, when trimmed properly, you want as much of the lower unit / midsection out of the water as possible and the cav plate parallel with the surface of the water.<br /><br />c/6<br /><br />Hooty
braindead0
Does the trim affect that much? As my motor is mounted directly to the transom, I can't really adjust the height. I'm pretty sure the cav plate is right at the bottom of my hull (have to double check that).<br /><br />Thanks.
ZmOz
Yes, the trim does have a big effect. That's why alot of boats have power trim, so you can adjust it while you're going.
braindead0
I'm guessing that if the motor is riding a little low in the water, I should trim in a bit (which in theory lowers the front and would cause the motor to ride a bit higher)?<br /><br />The stock mount has several positions for trim.. It's currently out around 10-15 degrees or so (at a guess). Hope to be out again this weekend, and I'll watch the engine while my wife brings up up to full throttle.
Hooty
Your mounting brackets have four holes in them. This is to accommodate raising and lowering the engine on the transom. If necessary, you can use shims between the bottom of the clamp and top of the transom.<br /><br />c/6<br /><br />Hooty
Hooty
Here's Hooty's 'KatCanDo' trimmed out.<br /><br />
Way cool pic Hooty! Sometimes a picture is worth a thousand words! Nice looking peice of fiberglass! Now tell the truth Hooty! Did you edit the pic and add the star on the port rub rail? Nice touch :) <br /><br />Link
Hooty
Wood eye? ;) <br /><br />c/6<br /><br />Hooty
braindead0
Not on this one, it's only 25HP.. clamp on (with two 1/4" bolts for security. I can adjust the trim however....
Dhadley
Hooty, youre draggin too much hull. Do it like this...... <br />
Hooty
Hey Hadley,<br />Your foto didn't work. Try again, I wanna see.<br />That's an old foto of the 'KatCanDo'. I'm running a cleaver prop now that gets about 6mph more boat out of tha water.<br /><br />c/6<br /><br />Hooty
Dhadley
Cant seem to get the pic bigger so go here and click on the pic.
Hooty
Yeah Hadley,<br />That's the ticket alright. <br />Wish I had a V8.<br /><br />c/6<br /><br />Hooty
Dhadley
Naw, the V6 is plenty. Monty tried a modified V8 on a boat just like that and it overpowered the hull and made it run on one sponson.
