I have an '86 Alpha 1 with a Mercruiser GM 3.0L. It has an Oildyne-Eaton hydraulic pump and the trim control on the throttle lever.
I just completed a comprehensive list of maintenance work on the out-drive -new bellows, hoses, lower shift cable, gimbal bearing, new U/Js, water pump, resealed the upper leg, and new trim sender/limit switches.
Before doing this work, there was a problem whenever I would use the trim causing the engine to misfire and stutter. I put this down to the fact that the wires were shorting in the bell housing where the insulation had fallen off. I assumed the new switches would cure that.
Now I just took the boat to the lake to test everything out and for about 20 minutes, everything was fine. Go, stop, reverse, WOT for a few miles, no problems at all. Getting a good smooth 40mph easily. The trim worked fine and the gauge worked too.
Then, I began to get the same symptoms as before when trimming and I also noticed that the voltmeter would jog back to less than 12v each time I pressed the lever. After that, the motor would misfire and run rough all the time whether I used the trim or not. Then, after mooring for a cool-off period, it ran perfectly well again for a bit but the trouble soon returned.
So I disconnected both the trim switches and tried the boat again using the trailer button for "UP" but it was still the same with the motor running rough all the time.
Sorry this is so long but any help or ideas would be appreciated.
