Trimproblem with the Yam F100
mish
Hello there,
My name is Michel from Holland. I enjoy this forum very much.
I have a Yamaha F100, year 1999. I great engine, but i have a little problem with it.
When i trim the motor out of the water, the motor 'locks' on the top end. The motor doesn't trim back. I hear the trim running, but no result.
Is it possible that there is to low oil in the trimcilinder? I can't find a technical draw of the trim.
Thanks, and grettings from Vinkeveen (nearby Amsterdam)
Michel Verbruggen
Hoffmann
Re: Trimproblem with the Yam F100
Did you figure out prob? Mine is doing the same thing!
rodbolt
check with a yamaha dealer for a tech buliten on it. there were some of the inline 4 strokes with a main valving issue.
there is a fix for it but find the tech bulliten.
mish
Re:Trimproblem with the Yamaha F100
Hello,
Thanks for the question and reply!
Yes, i went to the local Yamaha dealer. He disassemble the cilinder. The cilinder was at the top damaged. A cilinder cost about 700 euro.... The motor is fine, but 10 years old.
Solution: he make a mark on the bracket. When i trim the motor up, i dont go past the mark. He's almost on the top.
Is there a fix for it? Where can i find this? Thanks!
Greeting from the Netherlands
Michel
