tritoon+merc 250xb+30ft long=what prop
wedge542
i need help deciding on a prop,,,this 250xb is a powerhouse,,,be on a 30ft tritoon,,,what pitch prop to maybe start with,,,im getting motor without any prop.
a1nowell
Re: tritoon+merc 250xb+30ft long=what prop
A 15 inch prop with 15 inches of pitch, stainless is pretty middle of the road for power and speed. For more speed, 17 or 19 inches of pitch
5150abf
Check with a local marina or call your engines maker and either should be able to get you in the neigborhood.
lmuss53
Use this or a similar prop selection aid to get you a starting point.
http://www.mercurymarine.com/propellers/prop-selector/#
You can easily get thousands of dollars into props fine tuning a high performance hull. I know guys who have had a half dozen stainless props in 2 years looking for 3 more MPH.
The Rooster
Ensign
Hey "Wedge", if it helps, we're running a 14 1/4 x 19", Apollo, 3 bladed, stainless prop on our SouthBay 25 triple tube. Actually a little over 27' tube length. Similar motor, Merc. Optimax 250 Pro XS. Motor rated for 6000 rpm's and we're close at 5900 + with a light load. Good luck.
