Re: Trolling motor advice
DJ3
The Minn Kota site has a "Motor Selector" that will tell you what size you need.
Unless your boat is very heavy and has a whole lot of windage, a fifty five pound thrust model would be plenty.
I have a sixteen foot jon boat that I use fishing in small lakes but I have taken it on the Arkansas River. It has a basic forty five pound thrust Motor Guide on it and it is plenty and then some. I wish it had a variable speed rather than a five position switch. I use in in areas that has a lot of stumps and I am going on my third shaft. You may want to consider a flexible shaft.
For me, I would just as soon have a tiller control on the bow as a foot control. It is kind of six of one and a half dozen of the other; however, I have not used one of the new models that uses electric motor(s) to turn the foot and you operate it with a switch which could be a foot control or hand control. I think I am in the minority in that department. Some of the models even have a auto pilot.
Something to think about that relates to what I mentioned above, if you have a lot of power and a five position switch, you may not be able to slow the boat down enough for you application. I have that problem on my sixteen foot jon.
I was told by a tech in a repair shop that Motor Guide has problems with their remote control models. Minn Kota had it first and they seem to have it worked out. Take that for what it is worth. In all other categories, I think Motor Guide is comparable to Minn Kota.
If you will be using it a lot, I would get a model with what Minn Kota calls their digital maximiser. If thier clams are correct, it extends you battery life, as in charge, quite a bit.
Sorry for such a long post but I have just been through the same thing you are going through. I later found out there was no good way to mount a trolling motor on the bow of my boat.
Good Luck and I hope you catch a lot of fish and have a bunch of fun.
Please let us know what you come up with and how you like it and why.
Grits
