Trolling motor disrupts sonar image
Towrope
I have a 1997 Minn Kota model 865, bow mount trolling motor with Auto pilot. When operating it interferes with the sonar picture on my Lowrance Hook 9TS. All other features on the 9TS work fine. They share a new Lithium battery. The cables do not run near each other. Why does this occur and what is the solution? Thank you
Guessing, but trolling motor on the bow means it's stirring up the water, and making bubbles. Sonar can not read thru bubbles nor can a depth finder. But will see if @dingbat knows better
airshot
Is the transducer in front near the trolling motor or in the rear off the transom ?
dingbat
Not much to go on..... you didn't describe the type of interference nor under what conditions it happens.
Where is the transducer mounted?
Trolling motor.......12 or 24 VDC operation?
Install the ferrite on power cable?
Common ground connection between the two units?
A bad or failing electric motor will introduce "noise" into the system.
Towrope
Transducer mounted on stern, 12volt, common ground. Unfamiliar with "ferrite on power cable"? Interference consists of most all fish and structure images disappearing while trolling motor is running. Bottom dept still on screen. Sometimes I get vertical lines across full water column. The moment the trolling motor is turned off everything works fine.
cyclops222
What is the voltage when operating ? Of the trolling motor and the sonar battery ? Do they have their own battery or do they share ?
Is the interference only with the motor running at certain speeds ?
dingbat
Aluminum boat?
Auto pilot connected to Lowrance as well?
Network cables?
Not ideal to power an electric motor and sonar off a common battery. Especially if it’s “switching” power to minimize battery usage.
Throws off large, electromagnetic pulses with each switch. Only get worst as motor wears
Pull either unit off the common battery and power separately. If the problem goes away, you have an EMI problem
Because of the elevate frequencies in use with side viewing, most come with ferrites for the transducer. Surprised Lowrance didn’t supply a ferrite with the unit
Towrope
Aluminum boat?
Network cables?
Aluminum boat?
Network cables?
Yes, Aluminum boat. No connection between auto pilot and trolling motor other than a shared power source. No network cables and no ferrite beads. I will use separate power sources and obtain ferrite beads and report back on the results. Thank you all for the excellent suggestions.
mmasco
Buy the Murata BNX002 electronic component from a radio parts store (Farnell, Mouser, Digi-Key) and install it in the gap in the sonar power cable, as close as possible to the sonar, and ideally in the sonar itself.
It will remove all power supply interference, much more effectively than a ferrite filter.
Towrope
Well, it took a while to get back on the water. Ferrite filters had no effect but, hooking up to a seperate battery from the trolling motor resolved the issue. Thank You all for the advise.
