Re: trolling motor for 215 deckliner vip
I have SX951080 SmartTabs. There perform a bit differently than other trim tabs because they always have constant force on them in the form of weight applying downward on them through actuators (80lbs on each, hence the 80 in the part number), so their attitude/position raises automatically as water pressure against them increases as the boat increases with speed. They do not have a control system, which makes them far less expensive and easier to install. Most other makes of trim tabs, such as Bennet and Lenco, control the actual attitude on the trim tabs, through hydraulic or electric actuators with a control module mounted at the helm for adjustment, and some even have an optional automatic boat attitude adjustment by adjusting the trim tabs in response to the attitude of the boat.
I wanted to get on plane quicker (definitely did that on my rig), maintain plane at a lower speed (lowered by 2 to 3 mph), and minimize porpoising without having to run the leg at an angle that was less efficient for straight-ahead propulsion (did that real well too). I have not have positional attitude issues with the boat (probably due to the hull design compared to some v-hulls), even on trailing seas, so they have worked real well for my application (2 to 4 people).
I rarely carry more than 4 people on the boat, and 80% of the time there are only 2, so I do not usually have issues with the nose in the water. I have had large waves wash into the boat over the nose, but it makes its way quickly to the bilge area and then I just hit the bilge pump switch. We definitely wear life jackets when the wind is up.
There are many posts relating to trim tabs, and the difference between SmartTabs and the others on the iboats forum. If you do a search with keywords such as "trim tabs", "SmartTabs", "Bennet", and "Lenco", you will find many experiences shared. If I thought it was worth it for my setup, I would get Bennet Trim Tabs with the optional automatic control. I haven't looked for some time, but I think, with the auto-control, a setup would retail around 600 to 800 dollars, plus the time and/or money to install them. SmartTabs were under 130 dollars delivered to my door via courier.
