Re: Trolling motor for Key West 1720CC
Well, I finished the install the last week of April. I was able to put the nuts on the through-bolts using the port navigation light, thereby not having to cut a hole in the anchor box. Actually, my buddy who is about 5'10" got his hand in there with a 4" crescent wrench. I turned the screw from up top and he held the nut. Worked out pretty good and it's a clean installation.
As for the battery, I put a group 27 deep cycle along with the group 24 starting battery both in the battery box on the stern. The setup in the box (for future readers) is my fuel/water separator along the transom, gr27 battery running parallel to the transom, then the gr24 battery perpendicular to the 27. Also, the circuit breaker is mounted above where the cables come out of the pipe. I even have room left over for 1 qt of spare oil.
The initial ride was fine. Couldn't tell a difference in balance. It's no worse than if you had one person sitting on the left side of the bow compartment. However, this past weekend I fished and had a full live-well. That extra weight with the new battery really caused bad stern-squat and the boat porpoised even on flat water and trimmed all the way in.
So I'm looking into a hydrofoil or smart tabs now. Any thought?
