Does anyone know if Motorguide FW-H7 transemn mounted trolling motor came be operated in salt water? Also I have a Bottomline fishing buddy 1200 fish finder that I was also wondering if it can be operated in salt water?
Thanks for any info....
Pete, The FF should not be an issue. Can you determine if the trolling motor is an aluminum case with a stainless prop shaft? If so, you are good to go. If you flush it well, yu can likely use any trolling motor.
