WrenchHead
- Joined
- Feb 15, 2009
- 120
I have a 5-year-old Motor Guide 46 lb thrust 12 v trolling motor. Last fishing trip my trolling motor started knocking on speeds 3 through 5. On speeds 1 and 2 it's quiet. I removed the three bladed prop and checked it for ballance or a belt blade and it looks fine. I checked the armature shaft on high speed to see if the shaft is bent but it's straight. I removed the two long bolts and the rear of the motor and there was no water inside. The bushing in the end plate shows no sign of wear. The motor is quiet on all 5 speeds when out of the water. Anyone had this problem and does anyone have a diagnosis/fix?
