Trolling motor mount transducer
Dotson
How high above the trolling motor prop should I mount the transducer? Thanks!
Silvertip
Re: Trolling motor mount transducer
It doesn't go above the motor - it mounts below the motor. I take it you think the transducer mounts on the shaft of the motor when in fact it does not. You need a trolling motor transducer bracket that straps the transducer around the motor housing so it sits below the motor like this!
John_S
You don't mount them over the prop. They are mounted in front of the prop, based on skeg design and trolling motor.
