Trolling motor power??
ssmith36
Have a couple questions thought I would ask here. I just put a 40lb thrust trolling motor on my boat, with a mercury 650 engine 12 volt system. Can i get by with running the same battery or should i pick up a seperate battery just for the trolling motor? Can I get a new battery for both or am i definitely better keeping them seperate?
Thanks in advance
Silvertip
Re: Trolling motor power??
If you like to paddle, then use the starting battery which is NOT designed to be deeply discharged. Trolling motors need a big deep cycle to provide reasonable run-time. By all means, keep them separate. You will need either a portable or on-board charger to charge the trolling motor battery. And before you ask, NO -- the engine does not have enough output to charge both batteries.
ssmith36
Thanks and I was pretty sure I needed seperate batteries ( someone had told me I could use one). Thanks
MH Hawker
You can use just one, how ever it is very very easy to run it down past the point of starting the gas motor. So a second just for a trolling motor is best.
