Rob Fisher
- Joined
- Feb 11, 2002
- 6
I have a 1998 minnkota Maxxum 74 (24 volt)and I had a cracked shaft which caused water to get into motor.I only realized this when I would hit the power button and there would be a 2-3 second hesitation before the prop would spin. i quickly replaced the shaft and cleaned and dried out the motor and all of its components. Although I got to it quickly rust had formed on some of the parts. I cleaned off all the rust completely and re-assembled the motor. I then ran the motor with no problems for two fishing trips then the hesitation started again. I figured water got into the motor again but when I disassembled it there wasn't a trace of moisture to be found.I dont have an authorized dealer to look at this thing with in a 125 miles of me and was hoping someone could give me some suggestions on what to try next.I have a good mechanical backround and have eliminated the chance of it being a switch problem. I was thinking of replacing the brushes. Any other thought would be greatly appreciated.Or if someone may have had this problem themselves. Thanks
