Hi all,
I am trying to determine the type of trolling motor that will work best for my boat.
I have a 20 ft center console C-Hawk:
http://images.boatsandstuff.com/nlarge/2012-c-hawk-20-center-console-hull-for-10995_21426240.jpg and
I'd prefer bow mount, but my boat has a bow rail.
I've seen advertised engine mounts, but I'm concerned with reducing gas mileage, ability to plane at lower speeds, and perhaps most importantly the fact that the engine must be down to use the trolling motor.
I'm thinking the transom is probably the better location, but I'm not sure how much room is required for mounting and usage. For example, will the mounting bracket hit the storage box, when not in use will it block access to the storage box?
I don't need to go too fast. I just want to control my drift and navigate in back bays for fishing in shallow areas (salt-water). At most, I'd like to be able to go against 1mph currents with light wind.
I keep my boat at a marina, and theft could be a concern if it is easily removable.
Any suggestions on a specific trolling motor? Best mounting options? Minimum thrust? Recommendations for determining these answers instead of trial and error? Thanks!
