Re: Trolling motor troubles
Turn the prop by hand to check it for binding. If it turns harder than you think it should there is either a bunch of fish line wound up behind the prop (remove it and check), or the bearings are getting tight. As things tighten up (same as getting into weeds), the current draw goes up and the circuit breaker can trip. Take a test light or voltmeter with you. Connect the negative lead to the NEG post on the battery. Connect the POS lead to the motor side of the circuit breaker. When the motor begins to act up, check the voltmeter. If it is showing 12V then 0 in the same sequence as the motor, the breaker is tripping. But you should also be able to feel the breaker and even hear it cycle.
