trolling motor
BMDODGE
any idea on the size (thrust) trolling motor i need on a 88' stingray 17' bowrider ???<br />it weighs about 2000 lbs.....thanks ,bruce
KM2
Re: trolling motor
Bruce, I have a 18ft four winns that came with a 40# thrust minn kota that was just not enough power for me. In calm waters and no wind conditions it was fine. I upgraded to a 55# thrust MK and it works a lot better. I doubt you would be happy with a 40 # motor on your boat. Make sure you get one with a shaft that is long enough. My biggest compliant with the orginal motor was when I put one of my 200# plus fishing buddies in the back of the boat the TM prop was almost out of the water, waves caused problems too. To make a long story short over 50# of thrust and 54 inch shaft. Good luck<br />Kevin
Luna Sea
Re: trolling motor
If your going to stick to 12volts buy the biggest 12 volt available. 24 volt may be better though, if you can store 2 batteries somewhere. I did some research and ended up with a 36 volt on my 20' Lund. You may want to opt for the long shaft too as I had to return my 52" for a 62". Bet your bow's higher than mine.... :confused: And if you can get the salt water version...... :eek: <br /><br />Here's a link to read........<br /><br /> http://www.bassangler.com/articles/crawford/paul-tm.htm <br /><br /> http://www.bowfishiowa.com/TrollingMotors101.htm <br /><br /> http://www.outdoorcanada.ca/control_power.html
lund17
Re: trolling motor
I have a MK powerdrive 55# with a 54" shaft. Plenty of power even in the Hudson river. My boat is a little lighter though. About 1600 I believe. I also like the microtouch foot pedal.
