I have two Minn Kota trolling motors, Both about 50 lbs. thrust. One is a bow model and one is a transom model, whose lower unit is trashed.<br /><br />I no longer have a boat that could use the bow mount. I want to convert the bow mount to stern mount. It would appear that I could use the transom bracket and head unit from the transom motor.<br /><br />The thing that concerns me is that the transom motor used four wires to the lower unit and the bow model only used two. From what I've observed with test leads, the second set of wires only become live when you pass half throttle in forward gear. My boat is very light, so I doubt I'll need full throttle very often for the trolling motor.<br /><br />Can this conversion work, or what am I not seeing?
