Re: trolling
I Troll for Walleye at between 1mph,+ 2.5mph.....<br />Trout at between 1.5mph,+ 2.5mph......<br />Salmon at between 2mph,+ 3.5mph.........<br /><br />I manage these speeds with a system I've put together over the last 5 or 6 years.........<br /><br />The System consists of(and in the order of Original Implementation)........<br />1) Drift Socks,....Originals were 44"s accross,...My New Custom Built 1s are also 44"s accross, but with alot of Reinforcing,+ Foam sewn into the hem of 1/2 of the Big openning,+ Lead Wire sewn into the hem of the other 1/2.... They Should deploy Much Better....<br />I Also added a set of Cleats about Mid-ship,+ an extra set at the stern, Just for the Bags.....<br /><br />2) A Torque-Shift Prop,...... It runs at 11"s of pitch, at trolling speeds,.... Till I Hammer the Throttle.....
<br /><br />3) An Over-Sized set of Bennett Trim Tabs,.... 12"s X 18"s,.....With the Prop at 11"s,+ the Tabs All the way Down,.... I can Normally troll at 3/4mph at Idle......<br /><br />I Don't use the Bags as often, with the Prop,+ Tabs doing the required job,...... But, there Are the conditions that Still require the Bags..........<br /><br />With the Full System deployed, I can troll down to Under 1/2mph.......<br /><br />If You question the viability of the Bags,......<br />Try tying on 2 or 4, 5 gallon Pails to the forward cleats of your boat,+ Try It..........<br />If you like the Buckets,... Go out,+ Buy a set of Bags(Drift Socks).........<br /><br />Good Luck......
