Ihave been having this problem with propeller slppage. The boat is a 97 ranger with a 97 merc 150 efi and a trophy plus 4 blade 25pitch prop.Coming up out of the hole,about half way out the prop starts slipping....back off the throttle alittle...it will catch and the you can hammer it and it will take right off.the prop is a flo-torq2 so i replaced it with a new kit....still does the same thing.Looking at the prop there are 4 holes in it ...they are on the hub towards the end where the thrust washer is. They are about 1/2 to 5/8inch dia.I notice only one of them has a plastic plug in it.Are the holes for some kindof ventilation to allow for slippage? And you plug them till it performs correctly.If i remember right,two of the holes were plugged....one might of come off.does anybody know of these props?<br /> thanks for any help<br /> David
