hogginhank
- Joined
- Oct 20, 2009
- 53
Finally got my tilt/trim put back together and it seems that the frothy air bubbles just keep coming up? I lifted it up and down 5 times(like the service manual states) and each time it did seem to get a "little" better but there is still a slight pause from when the slow movement goes to fast when coming up. How many times will I have to do this to get the air out?
We did the "5 times" cycle 3 times(and a number if times with just 3 cycles) and there was air that purged from the fill cap each time with frothy little bubbles and we waited 30 minutes between the cycles. It is about 32 degrees right now in Texas so would that have any bearing on the air bleeding out worse? We were working out of an open garage..
I am topping off the fluid each time until it is to the bottom of the fill hole so I know it doesn't have too much fluid. It works fine and no fluid leaks but it just seems like it is taking forever to get all the bubbles out?? Any input would be great. Thanks in advance.. Hank
