Trouble finding pin drive prop 92 25hp Nissan
Dr.
I recently bought a 1992 25hp Nissan outboard with non thru hub exhaust with a pin drive prop. I'm looking to replace the wrecked 9.9x13 prop that's on it but I cannot find that size pin drive prop for a Nissan. Will Johnson props work? Is there any other mfg with the same shaft size that will interchange? Also I see where it's simple on most Nissan 25hp's to convert to a 30hp. Will my 92 model convert the same way? Just a restriction plate? Thank you in advance for your time
Sea Rider
Check Tohatsu same year and model, fingers crossed.
Happy Boating
jbcurt00
Seems several sources only list tbru hub for 1992 25hp Nissans and Tohatsus.
Sure its a 1992 25hp pin drive?
Dr.
I was told it was a 90 model 25hp Nissan but looking for parts I found that Nissan didn't start making them (or badging) them until 92 so I just assumed it was a 92. I will try to find the serial # this evening. I guess it could be a tohatsu with a Nissan cowling?
jbcurt00
Perhaps, but I looked for Tohatsu too.
Iboats and 3 other sites all ONLY listed thru hub exhaust, no pin drives for several years before thru several after 1992, I checked
Dr.
Well thank you for checking into that for me. I'll get the serial # and check back.
Dr.
Turns out the motor is an 86 model. I still can't find the pin drive prop though... Any chance this is an older lower unit put under an 86 power head?
Sea Rider
That I know all Nissans were rebadged Tohatsu models with own color and cowling styles, if can't find that pin, can always make one from a SS same diam drill bit, just cut to lenght.
Happy Boating
Sea Rider
Ooops, non thru hub props are very difficult to find these days, are extinted dinosaurs, can't yours be repaired at a prop shop ?
Happy Boating
Dr.
Possibly. It's very thin and two blades are miss shaped. I'm going to take it to the prop repairers as soon as I get a chance
