Trouble gaining speed with 40 h.p. johnson
wildman59
I have a johnson 40 h.p. motor that has always ran great, but recently it has developed some kind of a fuel problem I think. The motor will start just fine, and go into gear but when I try to accelerate, it bogs out and dies. If im in nutreal and rev it up it will hesitate for a second, then it will clear out and rev up but when i'm in gear driving it will die upon accelerating unless I move the accelerator very very slow and slowly creep up to speed. I have fresh gas in it, and new plugs, any idea on what this could be? Thanks for any help.
crxess
Re: Trouble gaining speed with 40 h.p. johnson
Sounds like a partial restriction in the High speed passages in the Carb. Need a tear down and clean, possible rebuild.
Quick open throttle rams full air flow but limited fuel starves motor out.
Partial choke should verify
fergie
check to see if your timimg advance plate is sticking, had same mo with my 85 v4.
