Trouble getting Starter Out
russf
Does anyone have any advice on getting the starter bolt that is up against the flywheel cover out? Open end wrench slides off and will strip bolt, and not enough room between bolt and flywheel cover to get a socket on it. I got the other bolt out. The motor is a Merc 260 hp I/O
B_Eager
Re: Trouble getting Starter Out
How about a brake line wrench, "split box"?
sea wolf
thin walled socket on a breaker bar.
Capt Ken
Like ole Sea Wolf said except use a 6 point socket and don't expect to get the rachet under there unless you use an extention. If you have to, bend the dust cover in some to get it on.
anesthes
When you goto put it back in, pick up some alen head starter bolts (application: 1972 monte carlo) from your local speed shop. Make the next job easier.<br /><br />-- Joe
