Re: trouble intsalling lower unit
How much force is forcing it????? I got it up to where I could start the two nuts in the back, turning the prop ccw, turning the nut, till the prop locked. At that point I assumed (hoped) the spleens lined up. Then I, and I don't recommend it, bumped the drive up a bit and slid a jack under it. I jacked it up only enough to apply the same pressure I was using lifting it when I started (94 degrees here)and bounced it around a little until whammy! It slid up. Hopefully everything else will be OK and it will be easier next time.
