I pulled my drive to check the bellows job I did last year and to check the impeller. Now I can’t get the drive back on. The pic shows the furthest I can get it which is obviously not even close. What am I doing wrong? It is not a shift shoe issue as I am not even close to those touching. The shift arm is inside the drive and mating with the gear shift arm (thing with the roller). The shaft is through the bearing but is hanging up on something or not mating with the splines in the engine. I have tried rotating the splined part that is connected to the ujoints. Is it simply a matter of continuing to slowly rotate the ujoint until it slides into the engine? Last year I just jiggled it a bit and it slid right in.
