Im up to $3,200 on my free boat My uncle gave me.Now when I try to start it i get nothing If I spray starting fluid in the breather or spark plug holes it will start and run for 5 seconds.When i try it again it will run for 10 sec on 3rd or 4th try it will say running. rough in the begining then smoth out and run great.all the way to full throtle for an hour then if i shut it down for what ever reason it wont start and I have to use the starting fluid again.If I disconnect the fuel line on the carb side of fuel pump and pump primer ball I get fuel If I try to start motor I get a trickle or nothing any help would be appreciated
