Trouble with 1980's Johnson 6hp......
Remkid
Ok guys i need your help, i have a Johnson 6hp outboard and ive been having problems with it. It ran great until one fishing trip i was running it and the rpm range started to surge. So i could run at full throttle which meant i had to idle all the way back to the dock. When i got back to the dock i notice that there was a screw and a spring on the or the cover. It turned out to be the needle valve out of the carburater. I was told to screw it all the way in and then back it out 2 turns, i did this but then it would run i low throttle. Because of this i took the carburator off and brought it to a local outboard repair shop where they fixed it. When i picked it up they told me that they had to replace one of the gaskets because it was "water logged" (not the correct term) which caused it to be warped. I then took it home and ran it and it seemed ok other than a few adjustments i would have to make. But when i went to make the adjustments 4 days later, everything went wrong. It seemed like all i had to do was adjust the idling speed at first but then it would acclerate right because it would "bog down" then accelerate. This eventually led it to dying. After battling with this, it killed and didnt start back up. After i pulled the spark plugs out and noticed that there was black stuff all over them, so i cleaned them and within a few minutes they were black again. I checked to see of the carberator was gettin gas and it is. So if any one has any suggestions, i would appreciate it TREMENDOUSLY!
Remkid
Re: Trouble with 1980's Johnson 6hp......
sorry guys, i need to make a change to my post, when i said i could run at full throttle, i meant i couldnt
Remkid
oh and one more thing, at one point when i was makin adjustments gas shot out of the carb.THANKS~
suzukidave
I have an 88 6hp johnson. I am no mechnaic so my experience may be my fault but the carb on it has been the most finicky engine part I've ever encountered and it has done many of the things you mentioned, usually because it gums up with stale gas at the slightest opportunity. I have stripped the carb down 10 times over the years and I've given it to a dealer twice. Both times the dealer could not tell me what it was that got it working beyond that they had to rebuild the carb. <br /><br />Anyway, it sounds like while adjusting things you have got it running rich, but I think you have to start with figuring out why it needed adjusting in the first place. I would start over which means you have two choices. Take it back to the dealer (surely he should have tuned the carb when he fixed it) or rebuild the carb yourself. A rebuild requires a kit (about $20) and will take under an hour. You should have a manual to do it. On the bright side, in my experience two rebuilds in a row generally takes only 1.5 hours :D
ShafferNY
First thing I suggest is that you get a new set of spark plugs(Cleaning them never work for me, especially if your trying to tune the engine). <br /><br />Then turn the idle mixture screw back in a little ways. You've got it way to rich if the plugs are black.
Remkid
Ok guys, thanks for the replies and here are a few more details.<br /><br />1) My spark plugs were brand new when this problem happened.<br />2) Today i found that gas was continuously spraying out of my carb, so i will prob. go buy a carb kit tomorrow.<br />3) The year of the motor is an 88.<br /><br />Thanks for all the help guys, its really appreciated!
