My engine is running great, but the buzzer is non-functional. When I ground out the temp switch wires (either the tan/blue or the white/black) on either the engine side or control side and turn the key to run the buzzer does not buzz. I took the cover off of the controls and wired the buzzer directly (purple positive, cream/blue negative) and the buzzer works perfectly. The factory manual is a bit wrong in the regard that to test the warning horn you should ground the single wire that comes out of the temp switch when in fact there are two wires. I know the buzzer doesn't work in practice since my engine overheated and the buzzer did not sound.
I look at the control wires under the engine cowl and I cannot find the cream/blue wire to trace it back to troubleshoot. What color is the buzzer wires back at the engine?
I have also noticed that the two conductor black wire coming out of the oil tank is not connected to anything either. It looks like a ground wire plus a signal wire. It seems that someone may have completely disconnected the alarm system in the past? The factory manual seems to be useless when it comes to control and oil tank troubleshooting.
Chris
Chris
