Motor Boater Bill
- Joined
- Jan 29, 2005
- 488
I recently picked up a non-working Motorguide Lazer 320es. I'd like to dig into it a bit and see if it's worth salvaging. For starters, I want to see if the lower unit (the motor) is good or not. the controls and the circuit board in the head are suspect. I'm thinking perhaps I can disconnect the wires that come up through the shaft (pull them off the circuit board) and directly connect them to 12 volts to see if the motor is working or not, and proceed from there.
There are four wires that come up the shaft from the motor. Two are larger, black and red. The other two are smaller (blue and green I think). Can anyone give me some solid information on making some combination of these hot and what each of the four wires does?
Many thanks!
Many thanks!
