2000 Reinell Volvo/penta 5.0. I have a no start problem when the motor is hot. Will start in the driveway all day long but when we run it on the lake for 20 minutes or so we get a no start. Wait about 20-30 minutes and it will start up fine. I believe the ignition switch is ok as when you try to start you get the loud warning buzzer. That would tell me power is coming from the ignition switch, right? I think I can rule out the neutral start switch because when the motor isn't warm i can start it no problem go into gear, nuetral, start again....My problem is following the troubleshooting tips and going into the engine compartment. Where is the relay that I need to find? Also, any problem with running it on the muffs for 20-30 minutes in the driveway? I would like to try to duplicate this at home rather than on the lake.
Thanks
Thanks
