Troubleshooting Tachometer Help
halcrimm
Hey all,
Mercruiser 3.0L Alpha 1 Gen 2 I/O.
S/N OD714746 Engine
S/N OD671270 Transom
S/N OD665768 Drive
Working ever so patiently toward getting first boat in the water. Had the engine running the other day on the muffs (very nicely I might add) but found that the tachometer does not register RPM. I went to the manual to see how to test the tach but all it says is to connect a known good tach and compare the difference. I don't have a 2nd known good tach so I was wondering if there really is a way to test the one that I have. Is there a pick up (sender) of any sort accessible on the engine that I can check for a good signal going to the tach?
Any help would be greatly appreciated.
Hal
sptjet90Reflexx
Re: Troubleshooting Tachometer Help
it just reads off the negative from the ignition coil. It could be a bad connection but usually you would have some reading. Its possible the tach is just dead. You can pick one up for as little as 30.00 for a sunpro or something from advance auto.
gm280
Hey all,
S/N OD714746 Engine
S/N OD665768 Drive
Hal
First you need to verify three things. One is that you have 12 volts going to the tach, you have a good ground, and last you have a proper connection to the engine. If you already verified those three things and you still don't have any readings...it may be time to buy a new tach...
halcrimm
I will check thoses things tonight. I do know that when I turn the key I do get needle deflection to the 0 RPM mark.
