Hey guys, I'm helping out with a boat project my uncle has. It's a 1996 crownline that he bought with the engine pulled due to a cracked block and soft floors. He replaced the floors and bought a rebuilt 5.7l marine long block and we have swapped everything over(carbureted motor). We got everything connected and went to fire it off last weekend. it keeps acting like the distributor (thunderbolt V) is in 180 out... popping out the carb. I put the timing light on it as it was cranking over and the light comes on at the timing mark on the balancer so I can't see how it would be 180 out.... He has tested everything according to the manual and is at the point where he thinks the problem has to be the distributor/module itself.
my question is, would a distributor/module failure exhibit these type of symptoms? my understanding is you usually either get no spark at all or one spark then nothing with a bad thunderbolt system.
hopefully I will get a chance this weekend to get in and really look it over myself as I got it as far as hitting the timing mark last weekend before I had to leave.
thanks for your help
