First post here. First, a little history on my boat. Picked me up an '86 Sea Ox 230C a month and a half ago. Originally ran a AQ200D with a 290 Out drive, which has been converted to a DuoProp. Outdrive was rebuilt by the prior owner, and the 305 was replaced with a rebuilt 350 in spring of 2012. Motor is FWC with a crank driven sea water pump. Never owned or worked with I/O before, so I have actually been learning alot from this site. First voyage, boat ran well with temps about 140 deg on the gauge, for about two hours. When I got back to the no wake zone and headed for the docks, temp shot up to 190 then hit 200 (gauge max) by the time I made it back. Not to drag this out, but turned out that cyls 5 and 6 were cracked and water was getting in the motor, and had been for some time, as I found the cyls had corroded and pitted from water setting in them.
Since then, I have installed a new 350 long block, new impeller, new risers and manifolds, had heat exchanger boiled, tested, and internal leak repaired, new points, condenser, cap, rotor and wires. Maiden voyage with new motor started well last Friday. New motor ran smooth and no temp problems.
Then it went down hill after a couple hours. Motor seemed to be not getting fuel. Couldn't get above 2500 rpm without it trying to die out, backfire and cough (running the original Rochester 2bbl which was supposedly rebuilt last year also). First thought was fuel filter. Its running a Racor 320. Got boat home, bought a new filter and installed. I rechecked the points, dwell and timing and all were were they had been originally set.
Took boat out again yesterday and ran sweet for the first hour, then problem came back. Sat for about an hour letting the crab pots soak, started boat and it was running well again. By the time we checked and reset, problem came back. When it was time to head back, about 2400 was the most I could get and keep it running. Half way back, I noticed the engine sound smoother again, so pushed the stick fwd and all was well again.
Would this be fuel pump? Could the coil be causing me issues? Not sure where to go without starting to throw money at it. Suggestions?
